Roof by footprint, pick wall tool is picking wrong side of wall
micah
micah
Can someone help me to get Revit to select the correct EXTERIOR side of my wall? Every other wall for this roof picked correctly, but this little wall will not cooperate. Red line is what I want, yellow is what Revit is forcing.
22-006 - 660 Westgate Ln, AG - Cabreros SFR and ADU.rvt
Password: 7q3jAno9iYwL
https://msacloud.egnyte.com/dl/4kEdHsyneQ
Press the spacebar.
Click this.
Did you sketch the Roof in the Plate Level View?  If so, I notice that your View Range Cut Plane 50' above the Plate Level.  You might consider sketching the Roof in a View that actually cuts the walls. This wouldn't effect the Level that the Roof is to be place on, which you select at the beginning before you start sketching footprint.
FWIW.
