I have a structral beam system on the left for my roof timbers. I have tried to mirror it around the centreline of the roof, but it is offset as shown. What is causing it to be offset like this?
Looks like a join geometry issue? Can You post a 3D view?
Kunal Tuljaram Gaidhankar
See if there are any Start or End Extension values for Structural Framing.
@anze.kumar wrote:See if there are any Start or End Extension values for Structural Framing.
No, they are both set to zero
Maybe it's the Mirroring that does the problem. maybe try copying the Strcutural Beam System to the same place and then adjusting Boundary and Angle so it matches your desired geometry.
Yes unless you can group and copy/array them. And why does the beam not cope properly to the ridge but overlap it?
Did you try cutting the Beams with reference plane.
But like solution Toan suggested, you have to cut every beam within the Structural Beam System.
@anze.kumar wrote:Did you try cutting the Beams with reference plane.
Ok, I've trimmed all rafters to the ridge board.
