Roof beam system not mirrored correctly.
14 REPLIES 14
Message 1 of 15
tmccar
814 Views, 14 Replies
I have a structral beam system on the left for my roof timbers. I have tried to mirror it around the centreline of the roof,  but it is offset as shown. What is causing it to be offset like this?
Tags (1)
Labels (1)
14 REPLIES 14
Message 2 of 15
indiana_j0nes
in reply to: tmccar
Looks like a join geometry issue? Can You post a 3D view?
Kunal Tuljaram Gaidhankar
Message 3 of 15
anze.kumar
in reply to: tmccar
See if there are any Start or End Extension values for Structural Framing.
Message 4 of 15
tmccar
in reply to: anze.kumar
No, they are both  set to zero
Message 5 of 15
anze.kumar
in reply to: tmccar
Maybe it's the Mirroring that does the problem. maybe try copying the Strcutural Beam System to the same place and then adjusting Boundary and Angle so it matches your desired geometry.
Message 6 of 15
in reply to: tmccar
Which one is the original?
Message 7 of 15
tmccar
in reply to: ToanDN
The one on the left (the longer one)
Message 8 of 15
in reply to: tmccar
Disallow join before mirror it.
Message 9 of 15
tmccar
in reply to: ToanDN
Do I need to do this on each joist?
Message 10 of 15
in reply to: tmccar
Yes unless you can group and copy/array them.  And why does the beam not cope properly to the ridge but overlap it?
Message 11 of 15
tmccar
in reply to: ToanDN
I placed the ridge beam after doing the rafters - I was going to "cut geometry" on each one afterwards to trim them back
Message 12 of 15
in reply to: tmccar
Can you zoom in the original rafter and select it so I can see its grips?
Message 13 of 15
tmccar
in reply to: ToanDN
Is this any help?
Message 14 of 15
anze.kumar
in reply to: tmccar
Did you try cutting the Beams with reference plane.
But like solution Toan suggested, you have to cut every beam within the Structural Beam System.
Message 15 of 15
tmccar
Ok, I've trimmed all rafters to the ridge board.
