Riser Count mismatch
8 REPLIES 8
Message 1 of 9
Mohamed_Arshad
456 Views, 8 Replies
Hello Experts Hope everyone is safe and healthy
     I have a small query in Staircase creation, Kindly refer to the below image for additional reference.
@ToanDN @barthbradley @constantin.stroescu @L.Maas @mhiserZFHXS
Thanks & Regards,
Mohamed Arshad K
Labels (1)
8 REPLIES 8
Message 2 of 9
in reply to: Mohamed_Arshad
26 16 is the number of treads. Risers  = treads + 1.  If you want 16 risers then edit the stair, select the run and untick End with riser box.
Message 3 of 9
Mohamed_Arshad
in reply to: ToanDN
Hi @ToanDN
Can you please explain to me the calculation behind it? It will usefully in the full understanding
Thanks & Regards,
Mohamed Arshad K
Message 4 of 9
Explain? Just look at the stair in a section and count the number of risers.
Message 5 of 9
My Question was,
 In the above image, the total length of the stair path is 4000, and the tread depth was 250, So 4000/250=16, Actual number of risers should be 16. But I don't know why there are 17 Why?
Thanks & Regards,
Mohamed Arshad K
Message 6 of 9
Do you understand the difference between treads and risers?  You count treads on a plan, you count risers in a section.  Do it, there is no mistery here.
Message 7 of 9
Mohamed_Arshad
in reply to: ToanDN
Hi @ToanDN
Sorry, I was just confused with the number 26 which you mentioned in the above conversation.
As you said Riser Count =treads+1. If we need the same count as tread means, need to uncheck the checkbox end with the riser.
Then I need a small confirmation from you, Tread count is calculated by Tread Count=Path Length/Tread Depth is this correct?
Thanks & Regards,
Mohamed Arshad K
Message 8 of 9
Mike.FORM
26 was just a typo. Should say 16.
if your stair is set to start and end with riser then the amount of risers will be tread count + 1 as @ToanDN stated.
if end with riser is unchecked then the last tread will be at the same level as your floor and and thus tread count = riser count.
The check boxes are found by editing the stair and then selecting the run.
Message 9 of 9
Mohamed_Arshad
in reply to: Mike.FORM
@Mike.FORM
Yeah I got it Thank you Both Superheroes 🙂
Thanks & Regards,
Mohamed Arshad K
Forma Design Contest
Technology Administrators
