Modeling NURBS solids in Revit can be very frustrating and limiting on all but the simplest platonic geometry. These more complex NURBS models can be created easily in Rhino, but there is an issue when importing the Rhino 3dm model into a Revit Family for rendering in Revit. The ability to assign Revit materials to discrete objects in the imported model is lost from the Properties panel and from the Object Styles panel.
To successfully import Rhino models and retain the ability to assign multiple native Revit materials after import, the Rhino file must first be properly prepared:
Now import the Rhino file into the Revit family editor and assign Revit materials:
Thanks for sharing the steps! This will be helpful to the community seeking similar solutions.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
