Revit Yes/No parameter not showing box for linked file
SP-PRAJAPATI
Message 1 of 8
SP-PRAJAPATI
Hello All,
In this screenshot, the red one is in project and yellow one is it from linked revit file. Parameter is the same in both file 9 AM(Yes/no). But in schedule Project rooms are with check box and linked file's rooms are with Yes no value. How to convert that in check box. I hope you got this.
Thank you
Accepted solutions (3)
Replies (7)
Message 2 of 8
RSomppi
That cannot be changed for linked models. The value from linked model is only for reporting, not editing. You need to do the edit in the linked model.
Message 3 of 8
mhiserZFHXS
Not sure if your intention is for them to look the same or to actually modify the linked model. As mentioned, you can't edit a linked model, which is why the boxes are shown in their yes/no format. If you are just concerned about them LOOKING the same, they should both show as Yes or No once placed on a sheet.
Message 4 of 8
SP-PRAJAPATI
How can I make check boxes for the linked model as well?
Message 5 of 8
SP-PRAJAPATI
How can I make check boxes for the linked model as well ???
Message 6 of 8
RSomppi
You can't. That's what we are telling you.
Message 7 of 8
SP-PRAJAPATI
Thank you, You were right. I can't change Yes/No parameter in checkbox for linked Revit model. So I changed checkbox into Yes/No. 😉
Thanks Again 🙂
Message 8 of 8
mari.shimode
Hi @SP-PRAJAPATI, it's good hear you found a workaround. I have marked replies from @RSomppi and @mhiserZFHXS  as additional solutions as those are the answer to the question. Please visit the Autodesk Community if you have any other questions in the future.
Mari Shimode
