Revit workshared file is not stable.
dream.du
Observer Observer
dream.du
Observer
Observer
Hi, I worked on a worksharing Revit file recently. But I found it is not stable, especially compared with the non-worksharing file. For example, I changed the dimension or some detail lines, ect., and I saved the file afterwards. But the next day, when I saw the same drawing, it turned to be unchanged. And it also went wrong with the linked CAD file, the file cannot be shown properly. I searched for the answers, sometimes it worked, but some answers don't work out. But it didn't occur to me when I worked on the non-shared file. Besides, I worked on the Revit 2020. I don't know if the new version works better.
kimberly_fuhrman-jones
Hi, @dream.du
Welcome to the forums! As this is not a request for a new feature or enhancement, I am going to move this thread to the forums where you will be able to get support for the issue you are having.
Thank you for your submission!
-Kimberly
Kimberly Fuhrman-Jones
Revit Community Manager
RDAOU
  • Where is it workshared, on the Local Server/Network or on the Cloud?
  • Where you working on a local copy or the central when the work was not updated?
  • Are the Local and the Central using the same version/build? Both need to be matching and preferably the latest
  • Did u use sync after the changes?
  • Do you have read and write permission to the folder where the central is saved?
ennujozlagam
try to install latest updates from autodesk and before closing the file you have to synchronize to central and see if helps. thanks
