Revit wont make topography from points in AutoCAD file
Seychellian
Seychellian
I'm trying to create a topography from this point cloud and Revit wont play ball. Anyone know why?
I even have a points cloud txt file from the surveyor and when i try to use this to generate the topography i get the error "No points were found in the file."
Replies (10)
syman2000
You have to extract the AutoCAD points as CSV file and then you can import into Revit. See attached
Your point file translates into one weird looking Toposurface.
Seychellian
It’s a very rocky hillside. If you look at the autocad file you can see what it looks like. Those sharp pointy things are false readings that are generated from vegetation.
Whatever. I just saved your first three columns (x,y,z) to a CSV (Comma delimited)(*.csv) file and it translated fine in Revit.
FWIW @Seychellian: This is all your DWG is showing at my end:
...if I stare at it long enough, I do see a few Seychelles tropical palm trees.  😉
Seychellian
thanks, could you possibly send me that file? Or the topography itself?
Seychellian
Lol. I’ll send you the original when I’m back in the office so that you can see what sort of topographies we deal with here.
syman2000
Not sure if you check the CSV file I've posted. All you have to do is take that and import and choose the file.
Seychellian
Thanks!
Seychellian
@barthbradley @syman2000
This is the topography that we are dealing if you're interested
