Create COBie Space
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
daniel.peel
1153 Aufrufe, 3 Antworten
Create COBie Space
I need to build a Revit model of a Quay (as in a piece of infrastructure to moor ships against) and the client has requested a COBie file. There is lots of maintainable equipment on the quay so its not as strange as it might sound. I can see how to use the BIM Interoperability Tools to get a COBie file where i have rooms from which to get COBie spaces but how can i make my whole quay (or parts of the quay) export as COBie spaces?
Thanks in advance.
3 ANTWORTEN 3
Nachricht 2 von 4
JasonKunkel
als Antwort auf: daniel.peel
This feels more like a Revit Rooms and/or Spaces question than a COBie question. The COBie Extension relies on Revit Room and/or Space elements for the COBie spaces.
I would suggest diving into Revit Rooms. I am not familiar with Quays, but you might need to set some of your Walls to not be Room Bounding and rely on a lot of Room Separation Lines.
Create a Room | Revit Products 2020 | Autodesk Knowledge Network
Room Boundaries | Revit Products 2020 | Autodesk Knowledge Network
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
Nachricht 3 von 4
als Antwort auf: JasonKunkel
Room Separation Lines. Smart.  I think you nailed it.
Have a good quay.  :lächelndes_Gesicht_mit_lächelnden_Augen:
Nachricht 4 von 4
daniel.peel
Thanks for the reply - I believe this will work. I would prefer to create spaces rather than rooms (although i guess it doesnt really make a difference if both spaces and rooms export to 'Space' in both IFC and COBie). If I use space separation lines i can sub-divide the quay into operational areas where there are no walls dividing it up. Thanks again!
