Revit wont import CSV topography file
Message 1 of 10
Hello, I´m trying to import topography from a surveyor into the REVIT.  I have an excel file with x,y,z points. Saved as CSV. Everytime when I try to import it by ,,Specify points file" revit says ,,no points were found". I tried to look for many solutions but none of them worked. Tried to save the excel as an CSV ( comma delimited) or CSV UTF-8. But it gives me the same result. Uploaded my csv file into Attachments aswell. Thank you for your advices or tips.
Replies (9)
Message 2 of 10
That's not a proper CSV file.  Plus, the Coordinates are way too far away for Revit.
Try the attached TXT file. You can create a Toposurface from TXT files as well as CSV.
Message 3 of 10
revit - topo 2.pngthat is weird, it should look like this.
Message 4 of 10
also what kind of coordinates do you mean? x y?
Screenshots from autocad: autocad zam.png
Message 5 of 10
See my revised txt file above.
Message 6 of 10
is it cutout? because it shouldnt look like that or the part of it should but there should be 2 roads from both sides. Also can you tell me how did you manage to filter out the ,,751" and ,,116" from the begging of every number? or coordinates
Message 7 of 10
I think my x coordinates are wrong then. Drop the beginning digit from each x coordinate value.
Here's the main issue with your CSV file. Your xyz coordinates are all dumped into one colomn. On top of that, they are separated by semi-colons.  Revit translates COMMA SEPARATED x,y,z values - not semi-colon separated x,y,z values.   Lastly, the x,y coordinates are too large.  You need to truncate values.  Essentially this is like moving the Toposurface closer to the Revit Internal Origin.
Message 8 of 10
that is right they were all dumped into one colomn. My friend managed to fix that. And even after revit still showed me the  points not found error. revit - topo 3.png
Message 9 of 10
Are you sure this truncation doesn't work or is incorrect?
000.000, 000.000, 000,000
Message 10 of 10
revit - topo 4.pngNow, when I edit it with the points visible it looks correct. Thank you for your help. Even tho I would like to know why my CSV file didnt work. I did watch many youtube tutorials and they all did the same thing. And it did work for them. Maybe it´s because of numbers being ,,too big" for revit. I dont really know. But thank you for your help.
