Revit windows material appears solid in Lumion
rattywolf
rattywolf
I can't change any window parts material in exported fbx model to Lumion, all of the windows appear as a whole component, even though I have different materials assigned to glass and frame in Revit window family. How can I fix that?
Are you Phasing? Was View Phase Filter set to Show Complete?
rattywolf
No, that's entirely new project and I am not phasing
Are the different materials using a different Appearance Asset?
rattywolf
There are default Revit materials with no assets, do I have to create custom ones?
You don't "create" Assets. You assign Appearance Assets from the Asset Browser to the Material .  The Appearance Asset is what you see when you Render.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN....
betsy_kamali7QZGY
Community Visitor
Community Visitor
Hi I have the same problem. Could you fixed it?
