Is this ever going to get fixed?
4 ANTWORTEN 4
Nachricht 1 von 5
kgatzke
302 Aufrufe, 4 Antworten
Imagine if Revit could actually join more than 2 walls.
revit pleaserevit please
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: kgatzke
No need to imagine.  Revit has been able to do this from it's inception. Join Geometry.
FWIW:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN....
Nachricht 3 von 5
kgatzke
als Antwort auf: barthbradley
I understand how layer and core priorities work, and my walls were correctly created to begin with, but it still doesn't explain why this crap keeps happening.  Somebody can add a wall at the other end and that's enough to completely undo an hours worth of work forcing Revit to model a join properly.  It can't even join two walls properly if there's an extension of the base or top.
https://forums.autodesk.com/t5/revit-ideas/fix-the-way-revit-joins-walls-once-and-for-all/idi-p/8523...
Nachricht 4 von 5
I hear your frustration loud and clear.  Let me take a stab at it. Post the file.
Nachricht 5 von 5
kgatzke
I cleaned up this corner (SE) but the other corner (NE - north is right in plan view) opens up in response.  SE still looks funny and there's a small hole I can't get rid of near the low parapet.  Thanks.
