Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Revit Visibility Problem
7 REPLIES 7
Message 1 of 8
Vasilii_Bogdan
494 Views, 7 Replies
Hello I don't see anything below the Second Floor in Plan view in Revit 2019.
Could you please refer to the attached file and tell me what could be the reason? Thank youuuuuu!
7 REPLIES 7
Message 2 of 8
bin
in reply to: Vasilii_Bogdan
I guess it's not about the view range... can you upload a purged model?
Message 3 of 8
Could be Phasing. Set Phase Filter to "None" to verify.
Here's a cheat sheet to reference when you can't find "stuff" in a view:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Message 4 of 8
Vasilii_Bogdan
in reply to: bin
Thanks so much for reply.
However, the person below got it right it was phase filter which needed to be set to "none"
Message 5 of 8
Thanks so much! I was looking for answer to this problem for several days and you gave me short and right point that worked!
Message 6 of 8
bin
Good to hear, at least now you know it’s not View range issue. But you need to decide a proper phase filter for your view. None is more for trouble shooting.
Message 7 of 8
Vasilii_Bogdan
in reply to: bin
I am still on training with Revit and not sure what this phase filter is
all about. Will need to dig into it. But for now I just put it to "none"
and it worked! 🙂
Message 8 of 8
bin
