Revit visbility question
- Mute
- Permalink
- Report
I am working on a shared model with an Architect (I'm an engineer), so I don't want to cut up their walls/floors just as a work around to get my sections to show up the way that I want.
2 questions
1. they have their walls run full height, and not broken at the floor container. is there a way that I can override the floor container to show up infront of the wall hatching? Without making the walls 100% transparent. Same thing goes for the steel post that I have from the level above that I want continous through to the dropped steel beam. Is there a way to override that so it shows up solid and is easy to tell that post is continuous.
2. is there a way to fade the finishes/layers of the wall? I just need to see the stud and plywood for my detailing, so I'd like to grey out the other layers etc. I've tried doing filters but no luck.
