Wall's assigned surface pattern is a different scale in perspective view.
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Brian5TAQZ
313 Aufrufe, 3 Antworten
The vertical lines of the surface pattern of the wall is showing at a different scale in elevation vs. perspective view. See attached image. Is this expected behavior? The elevation is correct, with lines spaced closer together. The perspective view has lines spaced further apart (incorrect). Should they not display the same?
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: Brian5TAQZ
Is your hatch pattern drafting or model? Model is what I would pick if you want to maintain perspective and elevation
Nachricht 3 von 4
Use a Model Pattern - not Drafting.
Nachricht 4 von 4
Brian5TAQZ
als Antwort auf: syman2000
Yes, that fixed it, thank you!
