Revit View with similar settings (no view template) not showing the correct model display...
8 REPLIES 8
Message 1 of 9
dpatriotaW9CR9
376 Views, 8 Replies
dpatriotaW9CR9
I have two similar views (With exactly same settings) one is correctly showing the hidden model display. The other is not...see attached file...
8 REPLIES 8
Message 2 of 9
"similar" but "exact".  Sounds like an oxymoron.  😉
Can't see much in that Screenshot. Too small. Post the File instead. That would be better towards getting a quick solution.
Message 3 of 9
dpatriotaW9CR9
Thanks for the clarification barthbradley.
Lets' go... with exact views settings. (No view template).
View '14th Floor Stair Tower' is showing my stair steps in wireframe model (even though the model display is set on hidden).
View '13 Floor Stair Tower' has exact same setting s and is showing the stair in 'hidden' model. Which is my goal. To view in hidden mode...
I have placed snapshot here ... attached the file... can you see it better?
Message 4 of 9
Check the View's VGOs. You can override Transparency there for Categories.
Message 5 of 9
Actually, I think the problem is with View Range Settings.
...you can post the file here if you want me to quickly resolve.
Message 6 of 9
dpatriotaW9CR9
Checked no overrides.  Also tried, creating a view template of the correct view and applying on the missing view. No change.
Message 7 of 9
Maybe one of these 33 will apply.
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
Also again, I willing to look at your file if you want to post it here.
Message 8 of 9
dpatriotaW9CR9
Thank you for the offer. Unfortunately, I can't post it here...due to the size file and NDA.... thank you though!
Message 9 of 9
dpatriotaW9CR9
Thank you very much for the link!
