Revit Trial not visible
5 REPLIES 5
472 Views, 5 Replies
Hi, I am 20 days into my revit trial and somehow nothing is showing up. the files aren't loading. I can see the ribbon and the properties tabs but I cannot see anything on my Ground Floor, nor Level 1 or 3D view, nothing. I am not sure if this has anything to do with the trial but I can't see anything, therefore I cannot work on anything.
5 REPLIES 5
ennujozlagam
hello, did you use the correct template? or try to untick use hardware acceleration and try to update your graphics card driver to the latest and see if helps. thanks
in reply to: ennujozlagam
Hey, so I've done all that but it is still showing the same screen. The computer ram is still running normal as usual and no sign of slowing down. There seems to still be no difference. Do you think it could be a source of something else or a setting in the program? (because I am sure I have been through all of the settings that have to do with the visual of the program)
Thank you.
ennujozlagam
hello, try to repair the program and see if helps. thanks
Hey I worked it out! So I right clicked on the icon. Then went to 'run with graphics processor' and went from there.
Thank you for your help though.
PrathapSekar
@Anonymous, could you please post some screen captures of what you did to get it off.
Thanks.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
