Message 1 of 23
Revit Topography created from DWG file (Civil 3d) not matching DWG file
06:45 PM
- Mute
- Permalink
- Report
Hi, I have imported DWG file (from Civil 3d) Into Revit 2019.2.
I did read all the topics about location too far etc and this is not theissue.
Problem is that imported 3d DWG looks exactly the same as it looks in Civil 3d, section looks the same too, but when I create topography based on that DWG file (it only has contours and triangle mesh) in that DWG file - created topography do not match DWG file (or it is very inaccurate, it seems like it is using only contours, but not using mesh to create it?).
How can this be fixed?
Screenshots showing this issue and DWG file attached.
TA!
Ziggy
