Revit Topo - Section box and below ground patterns
jmayo-EE
Mentor Mentor
jmayo-EE
Is it possible to turn off the brown topo patter below the ground when the section box cuts the model?
John Mayo
RDAOU
@jmayo-EE
  • Do you mean to stop it from filling the basement? In such case you need to place a building pad at the footprint of the basement
  • Or do you mean entirely switch it off?
    • One way is to Change the Poche material to Air and make transparent
    • Another is to make the Poche Elevation Base "0"
Edit: Seeing that tunnel in the image, building pad might not be ideal for that spot...and you might need something similar to what is discussed on the following Post
https://forums.autodesk.com/t5/revit-architecture-forum/earth-filling-the-plan/m-p/9260427
jmayo-EE
Thanks for the tip but I don't believe a building pad will expose the piles or the culvert opening. I did try this with the basement but that didn't help either even with a transparent material the cut topo shows. I really need to turn of the brown topo cut patterns to see what I need to present.
John Mayo
jmayo-EE
Need some time to look at the other solutions. Will reply back soon.
Thanks again.
John Mayo
jmayo-EE
Bingo!
#2 hit the nail on the head. Changed the poch material.
Thx a bunch
John Mayo
