Revit to CAD Exporting Problem (Missing, invisible object and line)
youngcheol.jeon
youngcheol.jeon
Hi guys,
I have a problem that as you can see the picture, the floors are absolutely same material and condition.
But when i export to CAD File, the Red box part floor disappears. I check all of options line weight, color and re-create floor too.
It is 1:1000 scale, then when i did in 1:500, it shows. This is not an small object compare with just next two of walls.
Let me know it is an error by Revit or not and give me some advises
constantin.stroescu
maybe all this happens because you made the Export from a  View with a Temporary Hide/Isolate setting...
Have a look at this message when you Export from a Temporary Hide/Isolate:
There is a warning for possible unexpected visual characteristic..
  • So , either choose Apply Hide/Isolate, or Reset Temporary Hide/Isolate.
  • If you apply Reset , see if you have not a Masking or Fill Region in that place or other entity that could block the view..
Constantin Stroescu
youngcheol.jeon
Thanks for the reply.
There is some misunderstanding, i used Hide/Isolate for only show what objects missing.
So when i exported, i exported an absolutely normal condition.
And i cleared this problem to change "Graphic display options - Model Display - 'Hidden line -> Wireframe'"
I dont know why this happen but just lucky 🙂
Anyway thank you.
