Revit thinnest line possible
5 REPLIES 5
8645 Views, 5 Replies
Hi!
I`ve just started working for a new company that has been working in AutoCAD. When we make pdf:s and prints we have four different thickness on lines 0,05mm, 0,09mm, 0,15mm and 0,25mm. Now since I started we are going to switch to Revit (I have been working with Revit for seven years) and we want the same line thickness. I know how to change the line thickness in Revit and it looks nice on the screen, but when I print it the 0,05 mm line and the 0,09 mm line looks the same.
Is there a way to make thinner lines than 0,085mm that I’ve read on different forums is the thinnest line to plot from Revit? Or some plugin that will help me get lines thinner then 0,085?
Thanks for the help!
/William
Hi!
/William
5 REPLIES 5
Viveka_CD
Viveka_CD
Autodesk Support
Autodesk Support
Hi @Anonymous
I see that you are a new visitor. Thanks for posting and welcome to the Autodesk community!Smiley Happy
In Revit, The line weight dialog allows the line width to be set as thin as 0.001", but this is limited by two values:
1) The resolution of the printer and
2) The lower limit for Revit has always been 0.083 mm (0.0033”)
As a result, the thinnest printed line is about three times as thick as the smallest allowed user-specified setting and about two times as thick as the thinnest printable line at 600 dpi. With larger dpi, the limit becomes more and more apparent, since the physical size of the "dot" decreases, while Revit's limit stays the same. Extra resolution should be gained by increasing the dpi setting of the printer.
We are not sure of any plugin for this one.
Please support a similar idea in Revit ideas - Improve Line Weights for small-scale drawings - Remove .003" limit and feel free to add comments and please vote for this idea.
Additional information:
  • Use the Line Weights dialog to define the width of the pen used to draw lines in views.
  • To see Thin Lines type TL
  • Use the Quick Access Toolbar (see below) click on the Thin Lines icon, see status bar display in the graphic.
Thin Lines TLThin Lines TL
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Hi @Anonymous
in reply to: Viveka_CD
Hi!
Thanks for the information, it was as I suspected then that there is a limit and it’s too thick comparing to what we are used to do in AutoCAD.
We’ll have to make Autodesk change this so that the lines can be printed as thin and nice as in AutoCAD because we want to be able to do beautiful 2D drawings in Revit as well!
Regards
William
Hi!
Regards
William
Viveka_CD
Viveka_CD
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for following up on the ideas page.
Hi @Anonymous
akord2015
akord2015
The bug is still present in Revit 2024
in reply to: akord2015
0.003" limit is a designed limitation (undesired by some), but not a bug.
