Revit text printing issue
5 REPLIES 5
k.raghibi
150 Views, 5 Replies
I am having problems printing from Revit, the text does not print correctly it's either bolded or overlapping. I tried printing to pdf and bluebeam with the same results. One thing that fixes it temporarily is when I change the Display Scale in my computer settings but whenever I do that I have to close everything and sign out and it only works for the first 10 mins or so. Any help on this would be appreciated, thanks in advance.
Text after it's printedText after it's printedText in RevitText in Revit
This is the temporary fix,
Temporary fixTemporary fix
5 REPLIES 5
in reply to: k.raghibi
Set the Display Scaling to 100% permanently.
Toan Nguyen
Lachlan-JWP
Does this only happen when printing or does it happen on screen in Revit too?
k.raghibi
in reply to: ToanDN
It doesn't allow me to set it permanently
k.raghibi
in reply to: Lachlan-JWP
only when printing
Do you have Admin right to the computer?  Did you do it under Settings > System > Display?
Toan Nguyen
Forma Design Contest
Technology Administrators
