Revit templates english to decimal unit setup
Good day!
Since we have autodesk revit 2017, My problem is about in templates #2 setup on follows;
1. System default templates was setup in millimeter it is used in MEP system.
2. Architecture templates was setup in english, now my problem is how to setup in to millimeter templates?
Anyone can help us!
Eugene
Accepted solutions (3)
Hello @Anonymous
You can change the units for the specific discipline. Just go to Manage>Project Units>select the discipline you want to change.
Then save as template
ennujozlagam
@Anonymoushello, you can go manage > project units > change to millimeter and then go to big R logo and saveas as Template ( .rte ) then it will become your millimeter template  and give filename. thanks
Hi guys,
Thanks for the reply, your solution is granted
But i have little concern how to change the 4 elevation tag arrow on the screen same in meters, please refer on my attached in circle cloud.
Eugene
Hello @Anonymous
What do you mean change?
Please elaborate thanks
ennujozlagam
@Anonymous Hello, you don't need to change anything based on your screen shot, your project units were already in the meter, it is automatically your elevations are in meters, unless you want something else please elaborate more on want is your intentions? Thanks
Good day!
Anyway, I found myself on how to change the meter symbol as per circle attached.
Eugene
