Revit Sync Times
Revit Sync Times
Revit Sync Times
We are a team working on the same project. I run the worksharing monitor and can see that for a few of us
there is a long waiting period befor sync start. See below while others don't have this "waiting". No body working on
SteveKStafford
There is a small button in the upper right corner of that dialog, looks like a sheet of paper, on the blue bar that says Central File Access. If you click on that it will give you a report that tells you how long each sync has taken.
When more than one user starts a SwC Revit deals with the process a bit like an aircraft controller at an airport. It processes changes sequentially and doesn't deal with subsequent requests until it has cleared the previous request. You can avoid the waiting by cancelling the Sync and starting it again when the other users have cleared the dialog status.
Steve Stafford
