How to create a custom Fill Pattern in Revit?
I want to create a new fill pattern as per the image attached (1200mm high x 600mm width)
Any ideas would be appreciated.
Viveka_CD
Hi @Anonymous
Please see AKN article Create a Custom Fill Pattern
Let me know if this helps!
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
hugha
; Written by HatchKit
; HatchKit (c)1990-2018 Cadro Pty Ltd
; www.hatchkit.com.au
;-Date                                 : 23/10/2018
;-Time                                 : 5:58:11 PM
;-HatchKit Version                     : 3.1.11.2770
;-HatchKit Output Filetype             : Revit
;%VERSION=3.0
;%UNITS=MM
*600x1200,RUNNING HORIZONTAL 600mmx1200mm bond=1/2
;%TYPE=MODEL
90,0,0,1200,300,1200,-1200
0,0,0,0,1200
Hugh Adamson
Cadro Pty Ltd
How can the units be changed from inches to MM?
Otherwise it wouldn't work, i guess..
hugha
Try the attached file.
;-Date                                 : 23/10/2018
;-Time                                 : 5:58:11 PM
;%VERSION=3.0
;%UNITS=MM
;%TYPE=MODEL
0,0,0,0,1200
