Revit Stud Family Loading but now working in Project
11 REPLIES 11
Message 1 of 12
jazzsharma200
533 Views, 11 Replies
I have created a Stud wall Family but it isn't working on the project file when loading it shows in the project browser.
this is very important I have spent 1 whole day making this family.
some one resolve this issue
Labels (3)
11 REPLIES 11
Message 2 of 12
hmunsell
in reply to: jazzsharma200
This family is a Curtain Wall Panel. So i assume your placing a curtain wall with no mullions and and swopping out the Panel?
Howard Munsell
Message 3 of 12
d.ahmed.LW
@jazzsharma200 the family you have created is a Curtain Wall Element (not sure the exact english term as i am more used to the German Revit Terminology). As you can see in the screenshot below I am able to place it without any issue. You will have to place a normal curtain wall from revit, place the posts and then the element in between can be swaped with your family. Video Attached.
Tags (1)
Message 4 of 12
You can model this in the Project with Curtain Walls or Beam Systems using your "I Stud" Profile for Mullions or Beams.
Curtain Wall example:
Beam System:
Message 5 of 12
jazzsharma200
in reply to: d.ahmed.LW
but it doesn't fill all the length.
Message 6 of 12
This family you created is very inflexible when being used in the project.  Use curtain walls with mullions for stud framing.  If you model wall framing for a living than invest in some specialized add-in such as AGACAD.
Also, refrain from spending a whole day to make something that you are not sure how it will work, or if it will work.  For the future or course.
Toan Nguyen
Message 7 of 12
linkboy
try this
Message 8 of 12
...and try doing this with your family:
Message 9 of 12
jazzsharma200
in reply to: linkboy
Saved in a later version of Revit I am using Revit 2021
Message 10 of 12
jazzsharma200
in reply to: hmunsell
yes but it is not working in the project
Message 11 of 12
Is this what you are trying to do?
Message 12 of 12
hmunsell
several of us have tried using this curtain panel family with success. This issue is either with your model or how its being used.
If this has not been resolved yet, please consider uploading a Model file (RVT) you are trying to use this family in.
Howard Munsell
Forma Design Contest
Technology Administrators
