Revit staircase modelling facing issue
blessy_vazhappilly_c
Observer Observer
Observer
Observer
How can we provide the stair nosing along the marked path? Is there any way to solve this issue?
Accepted solutions (3)
lucdoucet_msdl
There aren't any built-in options for component stairs that will alow you to automatically model the two vertical portions of the marked path. Revit only has an option for the stair nosing to turn horizontally at each end of the step component.
One possible workaround is to add a guard-rail family with a balluster modelled to the dimensions of the nosing and vertical returns. In the guard rail parameters, you disable all automatically spaced ballusters and railings, selecting only to provide one balluster per step. The balluster familly would then havec to be modelled to the same rise and step width.
Upside: It moves with the stair and adjusts to changes in the number of steps.
Downside: You need to have a type for each combination of rise and stepwidth. I don't thick the balluster family can read the step parameter.
Hope this helps,
-luc
bhavani_sankuratri
Hello @blessy_vazhappilly_c
Did the information provided by @lucdoucet_msdl  help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Bhavani Sankuratri | Community Manager
_Vijay
@lucdoucet_msdl, Says there is no default way to make it, but alternatively you may use an in-place family. This is an easy way to fix such a scenario.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
bhavani_sankuratri
Hi @blessy_vazhappilly_c
I wanted to check in and see if you saw @_Vijay response and still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
constantin.stroescu
In such a case I'd use a concrete stair without Treads and Riser and I'd create a parametric Faced Base Family, something as the one from my example...Load into the Project and place it on every step..
(view in My Videos)
Constantin Stroescu
bhavani_sankuratri
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
