Message 1 of 1
[critical bug!] group editing window not appearing, CG does not work!
The edit block window sometimes does not pup up. also if the bug is active my shortcut for opening group does not word. de buttons on the main ribbon are gone. on de editing ribon you can see the buttons.
but if you opteh group you are cooked! you can not get out of it! Sometimes it helps to save the file. and it will appear back.
otherwise you have to restart after saving with the loss of the work that has been done in de group.
i work in quite big files via a server. restarting the project can take 20 minutes of my time!
i Think this is a critical bug!
to be clear : the wediting window does not exist! so the screen off hack is not usefull here!
