revit stair path in sketch mode
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there any arrow i'm missing that defines the direction of the slope when working in sketch mode (working with path and boundaries, not after i click ok!)?
I'm fixing the curve of the stairs as it's not close enough to the correct shape yet, and to do so i delete boundary on one side and redraw it (didn't find a way to move ends of a start-end-radius arc), and after i'm done I get the message that the stairs run and landing cannot be joined because the path is flipped for some reason! Tried many times, drew it in different directions, redrew the path - still always flipped and then if i try to flip after sketch mode the whole staircase flips, which is obviously not what I'm after. Here's before and after i edit the boundary
PS maybe there's a way to make some void form to cut the stairs (as far as i know that's impossible) or some other way to seamlessly integrate the stairs into complex spline shapes to avoid all this trouble altogether?
