Revit Space room number/room name schedule issue
Jes_Gonzalez
Jes_Gonzalez
Hello, I'm having an issue when creating a lighting schedule my space "room name" "room number" are blank in my schedule, my "number" and "name" work fine but I requires someone inputting information to those fields. Is there a way of making this work, or a work around? Thank you.
robert.klempau
Hello @Jes_Gonzalez,
A few questions first:
  1.  do you have a linked model?
  2.  do you have placed spaces?
  3.  When you select a Space, do you see 'Room Number' and 'Room Name'?
  4. Do your Lighting Fixtures have Room calculation points and are they pointing into the Space?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Jes_Gonzalez
I think I figured it out. All I did was pretty much use Space naming and toggled between the "Names and Numbers" and "Names Only" and that reset the new space I added in, and used the linked architectural Room Number and Room Name.
robert.klempau
Great!
so you found the Space naming utility!
That is a great tool to synchronize the Room Names and Numbers with the Space Name and Numbers.
So be aware that your Ligting fixtures need a connection to the Space to see the Space Name and Number in your schedule.
Either by being in the Space or at the edge of a space. for instance in the Ceiling.
As I mentioned, you could use/add the Room Calculation point in your family to be sure that the Space finds the Fixture.
Kind regards,
Robert Klempau
Cadac Group AEC BV
