- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there,
Is there anyone who could finish my small home made in Revit? The only few things what has to be done:
- Adding a door somewhere in the house (outside door);
- Extend the stairs in height so it's reaching the first floor level;
- Adding a few window frames and windows;
- Adjusting the garage door because it doesn't fit.
- Adjusting things that are not right (if necessary).
All the things mentioned above should be finished by the end of this day (10-25) if possible. I think it won't take a lot longer then 30 minutes! There is no need to work in layers or something.
Revit file + screenshots will be sent through e-mail. compensation: $6,00
It would be great if there's anyone who could do this for me! It means a lot!
Thank you! 🙂
