Good afternoon,
I'm in need of assistance, I'm trying to slope a Gable roof design and help would be appreciated. I know how to slope a flat roof with the slope arrow of defined slopes, but when I want to add defined slopes to the sides for a Gable roof footprints get a "warning: can't create footprint".
Please see images attached of what I have began with.
Solved by ToanDN. Go to Solution.
For a simple gable, don't use slope arrow.
Instead, use "defines slope" and specify the pitch of the sketch lines on the two sides of the roof .
ot sure what you're trying to do. Your picture shows a shed roof. You want to make it a gable using a Slope Arrow in combination with Define Slope? Can you show a picture of what you are trying to acheive?
...here's a gable. no arrow neccessary
I understand ALL that, now I want to tilt the whole roof up with an angle of 30 degree or a specific distance from a referenece level. That's what I have the slope arrow, I want it at 0'-0" at tail (one side) and 6'-0" at the head of the arrow (on the other side), BUT have a gable roof design
You mean like in this?
You can also get there with Modify Sub Elements and using Split Line
I have attached another image, it is a side view with a gable roof.
I have attached a new image, it is Gable roof and a tile detail on what I'm looking to do.
Use a flat roof then add split line and change sub-element points elevations. or create a mass with slopes then roof by face.
I appreciate it, the split elements work that's exactly what I was looking for , I really appreciate it.
Thanks again
You're welcome. Anytime.
...oh, and BTW: it's a "Split Line", not "Split Element", which is something totally different
