Revit sheets to pdf
Revit sheets to pdf
Revit sheets to pdf
does Revit have "sheet to pdf print"? If not, what would be the best free pdf creator available for batch printing?
Thanks!
Ilic.Andrej
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
what's your pdf printer name? I cannot see it from your print screen. Resolution is too small.
Thanks.
Viveka_CD
Hi @Anonymous
Please see similar thread on PDF printing
If you find posts have solved your problem, please click on 'Accept as solution' button below to help others with similar questions.
Thank you.
thank you. Is it possible to batch print to pdf when sheets are in different sizes? For instance, first sheet is A0, second is A3, and then again A0 etc.
Regards!
Not without some additional add-in.  You have to create different print sets for different sizes and print each set as one batch.
Viveka_CD
Thanks for pointing that out @ToanDN
@Anonymous here are some resources:
Batch Print for Revit
Workflow: Batch Print
Batch Plotting PDFs without having to manually save each sheet
Print to PDF paper size
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
