Batch Plotting PDFs without having to manually save each sheet
29 ANTWORTEN 29
GELÖST
Nachricht 1 von 30
jim3thornton
31961 Aufrufe, 29 Antworten
I am needing to plotting individual sheets so each pdf file contains the sheet number and sheet name for its title.
I have encountered to issues in this process...
1) I would like to be able to have only the sheet number and sheet name to be the pdf file name.
- currently I had to include a  <Extention/Prefix>  <Sheet Number - Sheet Name>
example :  ALF - Sheet - A2-23 - 1ST FLOOR PLAN - QUADRANT C
I would prefer to have only the Sheet Number and Sheet Name be name of the PDF, with no other work on my part.
example : A2-23 - 1ST FLOOR PLAN - QUADRANT C
2) The second issue is that with every pdf, I am prompted to name it ... <press enter>
- Is there a setting that that instructs the program to save the pdf with its default name?  That way I can let the program print while I away from my desk.
29 ANTWORTEN 29
Nachricht 2 von 30
als Antwort auf: jim3thornton
If you are willing to pay a little, try Xrev Transmit from the App store.
If you don;t want to pay then hit back I can show you my workflow.  It involves some extra work but not too terrible.
Nachricht 3 von 30
a_meteni
Here's a free solution:
1. if the Extension/ Prefix are similar in all files , You can use a batch renaming tool to rename your PDF files.
2. You can use any free tool to automatically click OK when you're prompted for the file name.
Nachricht 4 von 30
jim3thornton
als Antwort auf: a_meteni
So currently Revit cannot do this process internally?
It sounds both suggestions require additional work / application on my part.
Nachricht 5 von 30
a_meteni
Which PDF print driver you're using? In all cases, you'll need a PDF print driver to plot to PDF from Revit. @ToanDN solution offered you the tool to get what you need internally from Refit but with additional purchase. My solution will require additional two free tools outside Revit in addition to any free PDF print driver.
Nachricht 6 von 30
@jim3thornton
The sole reason I showed you the app solution is that you stated that you wouldn't want to do any extra work.
I myself don't use any paid apps.  I set the PDF printer to automatic dump all individual PDF files in a fixed folder then use a free file renaming app to batch remove the prefix.  It takes like 10 second to rename hundreds of PDFs.
Nachricht 7 von 30
Archigrafix_Norge
Hi @jim3thornton
We have developed Docuflow that among other features also batch publishes the sheets to PDF format. You can use the unlimited trial for 7 days. Docuflow can be downloaded from the Autodesk Revit App Store (link below).
https://apps.autodesk.com/RVT/en/Detail/Index?id=6842090281765127625&appLang=en&os=Win64
Feel free to leave us your feedback.
Luis Santos
archi systems as
Tags (1)
Nachricht 8 von 30
jim3thornton
als Antwort auf: ToanDN
If I can get the individual pdfs to automatically name themselves without I have to manually hit enter that would be a major step
Nachricht 9 von 30
jim3thornton
i am using adobe acrobat
Nachricht 10 von 30
You can set it by edit the Adobe PDF printer properties.  Pick a folder (better NOT a project specific folder and easy to access so that you can go there and cut and paste the PDFs to the correct destination folder).
And below is a screencast showing one of the ways to batch rename files using a free app.  I demonstrated how to keep only the Sheet number per another poster's request.  If it was only to remove the prefix then it would even be simpler by Replace a string of text with nothing.
Nachricht 11 von 30
Archigrafix_Norge
@ToanDN @jim3thornton
Docuflow can save all the sheets, with sheet number as filename, in 1 job. No prompts, no need to rename, and handles automatically landscape and portrait sheets in the same job, custom paper sizes without the need to create them manually in the printer. Docuflow is according to our test the fastest PDF creator for Revit and includes a PDF driver.
Luis Santos
archi systems as
Nachricht 12 von 30
als Antwort auf: Archigrafix_Norge
I think it's extremely poor form to push your paid software solutions on these forums, especially since you don't even sell your products through Autodesk's App Store, but use third party sales.
Multiple paid add-ins offer the same functionality as yours, and a lot of those are much cheaper than the absurdly expensive $100 yours cost.
Nachricht 13 von 30
Viveka_CD
als Antwort auf: Anonymous
Hi @jim3thornton
Another alternative to automate this batch printing process can be achieved through Dynamo.
See HERE and the link HERE for related information
Nachricht 14 von 30
Archigrafix_Norge
Hi @Anonymous
We spent several months developing, improving and testing Docuflow to simplify the process of creating PDF, DWG, IFC and drawing list in a single operation. We did Docuflow because we needed this tool (we cannot find a similar app with the exact same features), and wanted to work faster and stress free. Autodesk has QA Docuflow, and we are happy to make it available for an fully feature trial for 7 days.
Due to several legal reasons we unfortunately cannot sell it on Autodesk App store. But the same happens with many great apps to Revit that are available on the app store as free and trial apps.
We offer volume discount so the prices start much lower than you refer, and never reach 100 USD. It starts at 15 USD for yearly subscriptions (large volume) and 45 USD for large volume perpetual licenses.
If you have any questions or need help using Docuflow, or any other of our apps, we are here to help.
Luis Santos
archi systems as
Nachricht 15 von 30
My issue is not with your pricing OR your product.
My issue is that you're trying to push your paid software through free advertising on these forums. If someone else mentions it as a solution, fine, but creating a profile with that particular purpose just seems like incredibly poor form.
Nachricht 16 von 30
jim3thornton
I don't mind the sales attempts for new products ... truth is I will mostly likely be purchasing anything ...
but as I saw autocad develop over the years ... 3rd party solutions would slowly be integrated into the program as more users were requesting those tools ...
But from all of the post I have been introduced to multiple options to achieve the same function ...
Hopefully the Revit Programmers can added a more efficient Batch Plotting Method in the future.
Nachricht 17 von 30
sbrowne
I have to agree with Jim.  It seems that this should be built into Revit.  I have a drawing set of 700 sheets and yes, I can use a Dynamo script or a simple bulk rename utility to take out the word "Sheet", but why not have it built in?  Even the few minutes it takes to rename the PDF's for every revision does take time.
As you said, we can hope for a future release . . .
Nachricht 18 von 30
als Antwort auf: sbrowne
If you have the Bluebeam plugin for Revit, use the Create PDF button (under Add-Ins). This will allow you to do exactly what you are asking for.
Nachricht 19 von 30
shujath36
The video in the below link describes how we can batch print with their file names. I am looking to build one of such kind. It would be great if any one help me out in this as I am a beginner in .NET but I am hopeful about it and I think this not a big deal to develop one.
https://www.youtube.com/watch?v=1FXw_VM_wX0
Nachricht 20 von 30
Would recommend XrevTransmit
We use it in the UK as we have BS 1192 Numbering systems for ALL our documents.
XrevTransmit Picks up 'Your' Parameters within the Drawing Sheets including Drawing Titles (Sheet Name), if you should need that too.
