Revit Server
Revit Server
aluong117
Message 1 of 8
Revit Server
aluong117
I just built a Revit Server (Revit 2014), and I am trying to configure a workstation to be able to remotely connect to it. Apparently, I need to have Windows Server software installed on the workstation, but the workaround is to install the Accelerator by editing the setup.ini file and preventing the software from checking for the Windows Server software. However, this edit did not work for me. Am I doing this properly? Please advise. Thanks.
Replies (7)
Message 2 of 8
dzanta
Install Revit Server 2014 on a Windows Server 2008 R2 or higher
Install Extensions for Revit 2014 to allow for workstation to connect to RS
Create RSN.ini file on workstation to see RS
Check connectivity of workstation within Revit to see RS
Troubleshooting:
http://revitclinic.typepad.com/my_weblog/2011/01/10-revit-server-troubleshooting-next-steps.html
Help:
http://help.autodesk.com/view/RVT/2014/ENU/
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 8
Hi
Where can i download the Revit Server Installation file for 2014 and 2015 ?
Thanks !
Message 4 of 8
DarrenP
@Anonymous wrote:
Hi
Thanks !
it comes with the revit installs
its under tools & ultilities of the install screen
DarrenP
Message 5 of 8
dzanta
you can obtain the Revit Server 2014 and 2015 installation exe file within any Autodesk Revit product within the Tools/Utilities section such as:
Revit 2014
Revit 2015
Revit Arch, Structure, MEP 2014 and 2015
Building Design Suite Premium 2014 and 2015
You can also find it by searching within Google for Revit Server 2014 and 2015 download.
Message 6 of 8
aluong117
Is there a way to do this without having to install Windows Server, i.e., using the workaround I mentioned above?
Message 7 of 8
dzanta
Revit Server is designed to run on a Windows Server operating system.
Message 8 of 8
DarrenP
there is a way to do it but all your doing is forcing it to install on a non windows server OS it does not make it work properly on the workstation OS
you may run into issues
DarrenP
