Revit server
Revit server
不适用
341 次查看
3 条回复
1 条消息(共 4 条)
Revit server
不适用
Hi, im planing in buying a server but i dont  know wich one to buy. Its for 30 users also some of them will be working in autocad , if someone can give me some advice in wich processor is ideal .
thx for the time.
0 个赞
342 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
Diego.Faria
You mean a server, that's going to be used for Revit files storage and worksharing, not an actual Revit Server right?
As far as I know, any server will be able to handle Revit files. Since you're probably going to be using lots of workshared files, I believe your biggest concern should be network bandwidth and stability.
If you were talking about an actual Revit Server, you can check these references:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/S...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Diego Faria
LinkedIn
0 个赞
3 条消息(共 4 条)
不适用
revit server , it say 6+ and 3.0Ghz + , but does that mean user per core?? 30 user=30 cores??
thx for the answer
0 个赞
4 条消息(共 4 条)
不适用
Revit Server is only for Revit being used between multiple offices...and you will need more than one.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
So you will need a fileserver if you want both Revit and Autocad on the same server just in your office.
Take a look at this to get an idea what kind of server you may require:
https://www.intel.com/content/www/us/en/enterprise-reliability/enterprise-reliability-xeon-itanium-s...
0 个赞
