Help putting Design Options on different sheets
Sahay_R
Mentor Mentor
Sahay_R
A team mate needs help setting up sheets showing a different Design Option on each sheet. When the Design Option is set on one sheet, the other sheet switches over too. FYI the 2nd sheet was created by duplicating the original sheet.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
in each view (on each sheet) you have to go into VG where you will find a tab for design options - which tells the view which option to look at. if you dont do this then each new view will be looking at the (same) primary option by default
