Revit Server not working
aw89000
aw89000
I have to install revit 2019 that is compatible with a complex model. The only problem I have is I can't download the revit server. I checked all my system information including the min. requirements. My system is
- Microsoft windows 10 Pro 64 Bit
-Intel(R) Core(TM) i7-4470K CPU
-16 GB Ram
-DirectX 12 with shader model 5.1
It says revit 2019 needs a video adapter: DirectX 11 capable graphics card with Shader Model 5. I have the DirectX 12 with Shader Model 5.1. However, I'm sure anything higher is acceptable. I checked all my systems, they are fine. Everything's been checked. It's just really frustrating. Only my AutoCAD and Revit version 2019 student version is fine.
A week ago, a representative told me to have the education support give me a Network License to run the revit server. I still haven't received it yet.
Revit Server is installed on a server, not on your workstation.  It is for remote offices on the same network as the main office to work on the same projects and assist with syncing locally instead of across the LAN long distances.
Why do you think you need Revit Server?
aw89000
Oh, I thought it was required for any Autodesk program. So if a group is using computers at a school, and doing the same project on revit. This Revit server allows them to sync their work on the same project and the entire group can see the progress? If I'm installing this at home, it's not needed.
