Bent roof and columns don't cope
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
dariawerynska
493 Aufrufe, 5 Antworten
Hi! I need to attach columns to a complex roof - bent/meander in shape (visible in the attachment). However, when the columns pulled to the level of the roof (through the "attach top base" command) reach it, they don't cope with it... How to adjust it so that it copes nicely?
Thanks!
5 ANTWORTEN 5
Nachricht 2 von 6
cbcarch
als Antwort auf: dariawerynska
One method is to use an in-place Void, then Cut Geometry to trim the columns.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 6
Make the column just high enough to overlap the roof and use Join geometry to join them.
Nachricht 4 von 6
loboarch
Have you tried using the "maximum intersection" justification setting when attaching the column? (Or you can set it in the instance properties once attached.) That might connect it the way you want.
http://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-B65164C8-D71D-4107-A4DD-041FCD5116B7
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 5 von 6
als Antwort auf: loboarch
Excellent advice!
Nachricht 6 von 6
dariawerynska
Both solutions are so simple and work! Thank you! :))
