While working today I noticed three random folders in the root of the Revit Server
![rvs01-folders.png rvs01-folders.png](https://forums.autodesk.com/t5/image/serverpage/image-id/163329iF83FCF0E9DB06143/image-size/original?v=mpbl-1&px=-1)
I tried to browse to the Revit Server Web Portal and the Web Portal would not load. Below is a screen shot of the message and attached is the log.
![rvs01-servererror.png rvs01-servererror.png](https://forums.autodesk.com/t5/image/serverpage/image-id/163330i5D2BE36187D409E0/image-size/original?v=mpbl-1&px=-1)
Those folders do not existing on the server side of the folder structure.
![rvs01-serverfolders.png rvs01-serverfolders.png](https://forums.autodesk.com/t5/image/serverpage/image-id/163331i7F134D278454B315/image-size/original?v=mpbl-1&px=-1)
Hoping someone has seen this before and has some ideas of where to look.
I need to access the web portal to shorten some file / folder names to solve another problem.
