I have a schedule with different columns coming from different lengths parameters. I need to select these two different cells, sum them and obtain the total in a new column. Has anyone a solution for this? Thanks in advance.
Unfortunately in Revit you can't do cell to cell calculations only column to column
There might be a solution through a Calculated Parameter Column testing a unique identifier Parameter Field of the Rooms. Can you be more specific about what you are after? Also, where's the "Finish Height" Parameter coming from?
