Revit Schedule Customization
moazzamilyas
moazzamilyas
Can you please suggest us how can we change the schedule that is representing row wise in the Format 1 to column wise in Format 2 shown in the snap attached.
Thanks & Regards
RDAOU
@moazzamilyas
  1. GO to Formatting Tab and uncheck the blank Row
  2. Right Click the Title Cell and Edit Shading >> Set to Gray
moazzamilyas
@RDAOU
This is not what I asked for, I actually want to flip the rows / column values. But anyways thanks for your effort.
RDAOU
@moazzamilyas
Misunderstood what you meant by Format...From what you are saying now, it sounds like you want to transpose rows and columns which at present Revit does not offer a direct way of doing it.
It is Possible to do what you want using either of the following methods
  1. Either by using Dynamo (fairly easy and simple graph)
  2. Or by adding more project parameters and calculated values in the Revit Area schedule. (See Image Below)
There is an Idea posted on the following link in case you feel interested in giving it a vote
https://forums.autodesk.com/t5/revit-ideas/vertical-schedule-orientation/idi-p/7040737
