Revit Room Boundaries And Tagging ISSUE: there is really something wrong
LanggamanXavierMassed
Hello everyone! I cannot make a wall-defined room even though it seems properly enclosed when i used the "room" command. As seen in the image, under the "place room tag modify" mode, the T&B room highlight looks wrong but the other room seems to not have a problem, it couldn't seem to recognize the walls.
Thank you! I'm a newbie by the way.
RobDraw
Have you made the walls "Room Bounding" in the properties?
Rob
yes sir, the Room Bounding is checked in the properties
Anyways, It's working, thank you!
RobDraw
What did you do to fix it if it wasn't the room bounding?
Please share the solution so that others finding this thread might get some help.
Rob
Make sure the Base Offset is not > 0.
...but, if Base Offset is >0, change the Level's Computational Height to equal the offset.
