revit render siyah ekran
eksitugcee
1,663 조회수
16 답변
1/17 메시지
eksitugcee
merhabalar.revitte render aldıgımda tamamen sıyah ekran ıle karsılasıyorum.neden sıyah ekran aldıgımı çözemıyorum yardımcı olur musunuz?
수락된 솔루션(2)
1,664 조회수
16 답변
답변 (16)
2/17 메시지
feel around the door jamb - about 4'-0" AFF - for the light switch. Turn it on.
3/17 메시지
...joking aside, you've not given us much information here to work with.  What else can you share?
4/17 메시지
eksitugcee
ı don't find light switch,do you know where it is ?
5/17 메시지
eksitugcee
6/17 메시지
Okay. So what happens when you press "Render"?  Or have you gone that far yet?
7/17 메시지
eksitugcee
8/17 메시지
eksitugcee
It only gives the black screen in the background after the render time expires.
9/17 메시지
I don't know what to tell you. It looks like you are Rendering an indoor scene with Exterior: Sun Only and a bunch of missing  Appearance Images.   What do you expect?   GIGO.
10/17 메시지
eksitugcee
no, the project is an indoor restaurant.
My illumination is not complete yet, but I encounter the same problem in places where they are complete.
I changed the revit version and I cannot get it from the area where I was able to light render before.
11/17 메시지
RDAOU
수락된 솔루션
@eksitugcee
Take it one step at a time and isolate the problem
  • If you go to Rendering Dialogue >>> Artificial Light ...are the lights still there and switched on
  • If you go to Rendering Dialogue >>> Adjust Exposure ... Slid the dial to make it brighter, how would it look like the render
  • Are you using the right type of lights do they have a Photometric Web File assigned & Light Source defined
Lights and Light Groups existLights and Light Groups exist
Check ExposureCheck Exposure
Lighting Fixture IES & Light SourceLighting Fixture IES & Light Source
12/17 메시지
eksitugcee
13/17 메시지
eksitugcee
yes they are defined.
I checked the steps, the only problem is the artificial light button is not active so it does not detect the light by the way, thank you very much.
14/17 메시지
RDAOU
수락된 솔루션
@eksitugcee
Check what @barthbradley told you earlier...You are rendering Exterior Sun Only... Select Sun and Artificial >>> Render >>> then adjust exposure if it is black or too dark
15/17 메시지
eksitugcee
Yes, my problem was solved thanks to the solutions you provided. Thank you very much.
16/17 메시지
Sorry, but I can't view the two Solutions you awarded herein. All I see when I try, are these two completely sanitary screens.
I'm betting it has something to do with my own ineptness, but I'm not sure.   Could you please help me figure out why I'm getting sanitary screens when I try to view the Solutions?
17/17 메시지
Never mind. Found it! Light switch was on the wall to the left side of door - not to the right side.  Arrgh!
