revit render siyah ekran
eksitugcee
Message 1 of 17
eksitugcee
merhabalar.revitte render aldıgımda tamamen sıyah ekran ıle karsılasıyorum.neden sıyah ekran aldıgımı çözemıyorum yardımcı olur musunuz?
Replies (16)
Message 2 of 17
feel around the door jamb - about 4'-0" AFF - for the light switch. Turn it on.
Message 3 of 17
...joking aside, you've not given us much information here to work with.  What else can you share?
Message 4 of 17
eksitugcee
ı don't find light switch,do you know where it is ?
Message 5 of 17
eksitugcee
Message 6 of 17
Okay. So what happens when you press "Render"?  Or have you gone that far yet?
Message 7 of 17
eksitugcee
Message 8 of 17
eksitugcee
It only gives the black screen in the background after the render time expires.
Message 9 of 17
I don't know what to tell you. It looks like you are Rendering an indoor scene with Exterior: Sun Only and a bunch of missing  Appearance Images.   What do you expect?   GIGO.
Message 10 of 17
eksitugcee
no, the project is an indoor restaurant.
My illumination is not complete yet, but I encounter the same problem in places where they are complete.
I changed the revit version and I cannot get it from the area where I was able to light render before.
Message 11 of 17
RDAOU
@eksitugcee
Take it one step at a time and isolate the problem
  • If you go to Rendering Dialogue >>> Artificial Light ...are the lights still there and switched on
  • If you go to Rendering Dialogue >>> Adjust Exposure ... Slid the dial to make it brighter, how would it look like the render
  • Are you using the right type of lights do they have a Photometric Web File assigned & Light Source defined
Lights and Light Groups existLights and Light Groups exist
Check ExposureCheck Exposure
Lighting Fixture IES & Light SourceLighting Fixture IES & Light Source
Message 12 of 17
eksitugcee
Message 13 of 17
eksitugcee
yes they are defined.
I checked the steps, the only problem is the artificial light button is not active so it does not detect the light by the way, thank you very much.
Message 14 of 17
RDAOU
@eksitugcee
Check what @barthbradley told you earlier...You are rendering Exterior Sun Only... Select Sun and Artificial >>> Render >>> then adjust exposure if it is black or too dark
Message 15 of 17
eksitugcee
Yes, my problem was solved thanks to the solutions you provided. Thank you very much.
Message 16 of 17
Sorry, but I can't view the two Solutions you awarded herein. All I see when I try, are these two completely sanitary screens.
I'm betting it has something to do with my own ineptness, but I'm not sure.   Could you please help me figure out why I'm getting sanitary screens when I try to view the Solutions?
Message 17 of 17
Never mind. Found it! Light switch was on the wall to the left side of door - not to the right side.  Arrgh!
