Revit Realistic view graphic error in my alienware computer
Many thank you for your time.
I'm having some trouble while creating walk-through in realistic view (I'm creating jpegs and then combining them into avi files). Now coming to my actual problem, some objects are overlapping others and when I zoom in it is getting cleared out to some extend not fully. Is it because of my computer graphic problem or should I change any of the settings in Revit software?
And when I open the jpegs or avi files in other computers also I'm having the same problem.
Please see the attachment of my screen shot.
Thanks in advance.
cbcarch
Yes--this looks like graphics/display problem. What are specs of your GPU and PC?
As a test, try exporting the walkthrough a couple of other ways:
-Shaded or Consistent Colors
-Export as native ( uncompressed) .AVI instead of single frame jpegs.
Also, it could be the frame rate and Codec ( compression ) format being used. This is a bit tricky in Revit.
Take a look here:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/R...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Thanks a lot. It did work when I create walk-through in .avi format.
I thought it would be better if I do them as jpegs first. So that when my employer tells some changes, I can replace those particular frames instead of doing the whole walk-through again. It is taking 2 to 3 days to create 6 minutes video. I guess now I have no other choices.
I have attached my PC's specs and .avi video screen shot.
Thank you again for your time.
