Change shape of outermost layer in wall
6 ANTWORTEN 6
Nachricht 1 von 7
Marcus.Isacsson
565 Aufrufe, 6 Antworten
Hi fellas!
I need to change the shape in the outermost layer of a wall.
I've been fiddling some with "parts" but can't get it to work like I want to (change the shape in the bottom, according to red lines in pic).
I don't get enough of shape handles.
Any ideas? Thanks in advance!
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Marcus.Isacsson
Split part to smaller pieces then edit their shapes.
Nachricht 3 von 7
Marcus.Isacsson
als Antwort auf: ToanDN
Thanks for helping out. This happens when I try Divide parts -> Edit sketch and try to draw in an elevation.
Nachricht 4 von 7
That is because the default dividing parts workplane is across the wall. You need to set the workplane to along the wall by picking a wall face or a reference plane parallel to the wall when you start the command.
Nachricht 5 von 7
Marcus.Isacsson
Thanks. Got it working now, but not with the handles though. I've been using "Exclude parts" now.
This kinda works but I wonder if thats what you meant and if this is a good way?
Nachricht 6 von 7
cbcarch
As an alternative,
You could always just use a separate thin wall, and edit it's profile, instead of trying to use Parts for something complicated.
Use Join Geometry so openings cut through both walls.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 7 von 7
Exclude parts is a good way.
