Revit "Failed to open document"
Message 1 of 8
I accidentally format the pc and all my works are gone.
luckily i recovered some of my works back.
but when i tried to open it.
it said ''Failed to open document''
is there anything i can do
because it really important to me.
can i send the files to support for recovering it?
The files were made by Revit2018.
regards.
Replies (7)
Message 2 of 8
Avaris.
Message 3 of 8
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!
Can you please share a journal file? Let me know if you need help in locating the journal.
Message 4 of 8
thanks for replying
here's the file
Message 5 of 8
Viveka_CD
Hi @Anonymous
I received your message and your Revit file. thanks for sharing, however, I will also need a journal file for testing file.
Please see how to locate your journal file and let me know if you have any questions.
Message 6 of 8
I'm not which journal file i must use
so i zip all the file here.
Message 7 of 8
Viveka_CD
Hi @Anonymous
Revit Journal files
Please collect and attach journal files from the affected computer(s) using the following procedure. This process will ensure that only the relevant information is recorded in the journal.
  1. Close Revit completely (so that a new session can be started).
  2. Reopen Revit.
  3. Reproduce the issue.
  4. Without closing Revit, collect the latest (highest-numbered) journal file.
Journal files can be found here:
Windows 7, Windows 8: %LOCALAPPDATA%\Autodesk\Revit\<Product name and release>\Journals
Did you try an Audit before opening the file?
Message 8 of 8
I did try to open the file by using audit but it doesnt work.
here it is my lastest jornal file.
