Revit 2018 Cannot switch between program screens
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
ruiz
463 Aufrufe, 3 Antworten
Hello, I recently upgraded workstations and am now having trouble switching out of Revit 2018 to other programs (Outlook, Chrome, Calculator, etc.). The only way I can access these windows is if I minimize Revit, otherwise, no matter how many times I click on the icon in the taskbar or press Tab+Alt, Revit always stays on. Is this a Windows setting I need to adjust? Never had this problem with the previous workstation (ran Windows 10 and Revit 2018 as well).
3 ANTWORTEN 3
Nachricht 2 von 4
Viveka_CD
als Antwort auf: ruiz
Hi @ruiz
Welcome to the Autodesk community!
Sorry to hear that you are facing issues.
Can you please post a journal and a screencast of what you are experiencing?
Revit - Collecting and sending diagnostic data to Autodesk Technical Support
Nachricht 3 von 4
Visual Effects may have been turned off on your workstation.
Take a look here: https://www.thewindowsclub.com/disable-visual-effects-windows
Hopefully you have access and the IT Trolls haven't locked down workstations too much.
Nachricht 4 von 4
ruiz
als Antwort auf: Anonymous
Thanks mpwuzhere, somehow by restarting the computer a couple of times the problem has disappeared. I am working with IT to verify the information you sent is correct. Thanks for the help!
Tags (1)
