Revit Properties Drop Down Menu is not visible
When I have the SW opened in full windows Revit Properties Drop Down Menu is not visible!!!
I found out that if I reduce the windows of Revit, the drop down menu list appears in a side of the screen outside the window of the SW!!!!
like the image below
WHAT THE HEEELLLL!!!!!
Of course if I maximize the windows the list disappears... it's really very annoying!!!
Does anybody knows how to fix it?!?
I'm using Rvt2017 with Win10
In a P40Yoga with Nvidia Quadro M500M connected to an external monitor: HP Z24N 1920 x 1200
Stanis-74
turn to OFF checkbox of "discipline" in props of template wich you apply to this view
mpeperkamp
Hi @Anonymous
What you have to check is the following:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Kimtaurus
He's asking about a graphics problem, not how to change a parameter.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
yess!! great! it works!! wonderful!
it was very frustrating having the dropdown menu outside the monitor!!!
